Easiest way to control ROV over Cat5 (Arduino or RasPi?)
Posted: Aug 26th, 2017, 6:18 pm
I am planning on building my ROV with the main control systems and power onboard. Originally, I had planned on running some form of web server on the Arduino or Raspberry Pi and accessing it from my computer. If I do that, I would have to remove a few wires to run the analog video signal to the surface.
Is there a way to run a website on a Pi and input RCA video to it, which could be seen on my laptop using a direct connection to it?
I would then receive inputs from buttons pressed on the site, which would send commands to an Arduino to run the motor controllers.
Would that be possible? Would that be almost the simplest way?
