Add data logging to your ROV
Posted: Jun 21st, 2017, 9:20 pm
I've come up with a compact configuration based on a screw-terminal expansion board that breaks out all the pins nicely:
https://edwardmallon.wordpress.com/2017 ... ld-update/
Current assembly time for the basic unit is under one hour, and the terminal adapter board has M3 mounting holes. Wouldn't take much to adapt this layout for motor control, or other things more suited to an ROV
