Question about power converter cooling
Posted: May 3rd, 2015, 6:15 am
Hello all,
I have decided to use a power generator 230V from the surface. This is because the cables will be smaller and cheaper,
and because I want to have ample headlights without worrying wether it will deplete the batteries quickly.
This will require a power converter from 230V AC to DC, inside the submarine.
I am told that this will produce too much heat, which must be sinked somehow into the sea.
The solution I have found is to have a separate "power converter box", outside the main hull.
This box will be made of steel and contain the power converter, dipped in oil. In such a way, we have
a natural "water cooled" power supply.
How do you think of this idea ? And if anybody has done something similar, can you please post the link ?
An alternative I thought about is to have the converter into the main hull, and put the converter into
a solid material which will be good conductor of heat but poor conductor of electricity. But I do not know
of such a solid material (I dont want oils inside the main hull). This would make the construction much simpler.
Do you know of such a material ?
Thanks in advance! My progress is slow but steady. This is the final issue to resolve. During the summer
I will prototype an acrylic ROV for swimming pool usage, then build an identical steel hull for the real thing.
