Thinking big. Anyone look at using Sevylor 12V Electric Trolling Motor? 18lbs of thrust, cannot find the amp draw? What is the thrust to size ratio for an ROV.
http://www.walmart.com/ip/22086513?wmls ... 50&veh=sem
Larger ROV Idea
Re: Larger ROV Idea
There's no fixed thrust to size ratio that you need to follow but you can calculate your top speed using the equation
D=(1/2)CpAv^2 where D is drag force, C is drag coefficient, p is density of water, A is surface area, and v is velocity.
Set D equal to your maximum thrust force and solve for v using the frontal surface area of your ROV and the drag coefficient for the shape to find your top speed. Or pick a top speed and drag coefficient and solve for A to find to find your maximum surface area of the front of your ROV.
