Help with Cree LED 12v Power Supply
Posted: Dec 28th, 2013, 11:16 am
by SVSeeker
How do we power 4 - High Power LEDs - White Warm White, 3000K 2932lm, 800mA, 80CRI - from 11-13v Lipos?
Choose it for the size, lums, CRI, and Lum/Watt ratio. It will be easy to build a watertight housing for each like a small flash light (torch) so that the reflector cone and angle of the light can be adjusted to best suite the cameras.
http://www.mouser.com/ProductDetail/Cre ... %2FKfvcExV
--Doug
Project Page: http://www.submarineboat.com/Streamlined_Mini_ROV.htm
Re: Help with Cree LED 12v Power Supply
Posted: Dec 29th, 2013, 6:55 pm
by Sunktwice
Hi, TBH - not exactly sure of the question your asking ?
Do you need to know how to wire them up, or the "best" method for turning them on/off ? if you'll be using LiPo batteries, you need to pay special attention to the discharge rate and draw from the LEDs -if you drain the LiPos past their nominal lower cell Ve they REALLY don't like it.
Posted: Jan 11th, 2014, 12:35 am
by SVSeeker
Thanks, we figured it out. The question we were trying to ask is how to we supply power to these LED's and the answer is a constant current LED driver. A friend pointed us to eBay where there are several Cree LED arrays complete with 12v DC input drivers available. We have picked the 100 watt units and now have them. I saw spots for an hour after powering it up. 10,000 lumens is awesome. We got some reflector shields too that work great for focusing it into a beam.
http://www.submarineboat.com/images/Str ... driver.JPG
Has anyone tried Cree high powered LED's in seawater without anything more than potting the connections? Any advice there?
Posted: Jan 24th, 2014, 1:07 pm
by TigerShark
Deal Extreme (dx.com)has a great selection of Cree LED's, drivers and special lenses designed for them. I use two 5W LED's with diffusor lenses which really seem to provide a nice even light in the front of the ROV. I haven't dived with them yet so we shall see how they look underwater. The drivers are 6-18v I believe.
Posted: Jan 25th, 2014, 2:31 am
by Billrose
I know this may sound silly, even a bit bonkers. But you can have tooo Much light! the camera will 'see' in its own light visual range. In water the refraction is different to air.
For example driving a car in snow with full headlight creates a blinding 'back-scatter' of reflecting light from the snow back towards your eyes. The same thing for the rov cameras, particles will 'back-scatter' the light into the camera.
Therefore if you can control the brightness / or dim the power to the lights this will help.
OR... Direct the light in a off set pattern to illuminate the general area. Rather than a full beam.
(A quick 'Bodge' Tape over part of the light with electrical tape, as a quick fix.)
