I am planning on using a Turnigy 9X because I don't want to get into programming an arduino. I was looking into the different OSD options out there and need some help. I would like to see voltage, compass heading, etc. on my laptop.
A cheap osd that just shows voltage :
HobbyKing E-OSD http://www.hobbyking.com/hobbyking/stor ... E_OSD.html
Or replacing the rx with a FrSky D8R-II PLUS 2.4Ghz 8CH Receiver with Telemetery :
http://www.hobbyking.com/hobbyking/stor ... etery.html
Never even held one so I am not sure if it can give me the readings I want, using the different sensors that are available.
Any other options/ideas would be appreciated. Thanks
-Bob
Radio control on-screen display options help
Re: Radio control on-screen display options help
http://hobbyking.com/hobbyking/store/__ ... de_2_.html
http://www.foxtechfpv.com/rmilec-signal ... -1342.html
Have tested this and it works fine.
Also looking in to an OSD system. Still some searching around to be done.
Hope this helps
Hope this helps
