Page 5 of 6
Re: Rov from Norway,finished
Posted: Jul 3rd, 2014, 3:32 am
by fryslan76
Looks realy nice, looking forward to the first dive movies.
Posted: Jul 3rd, 2014, 10:55 am
by RoarRoar
I have now make a moulding forms to Tether, just waiting for potting compound from 3M.
moulding forms image:
to olegodo:
Yes,i running power down to the tether, 144 Volt DC :D is not sow dangerous,if you connect properly and use fuse.
My rov need only 1 amps to drive all 3 Thrusters,Light and system.
Right now,i live in Oslo.
Posted: Jul 20th, 2014, 2:00 pm
by RoarRoar
I have now tried the moulding forms i have made for Tether,but when you struggling in the cable very hard,the small wires inside the Tether break of.
Sow i throw the moulding forms in garbage,i made two aluminum tubes instead, i use first epoxy then the potting compound from 3M inside the aluminum tubes,the aluminum tubes should be on.
Finally the Tether moulding is now strong.
I have now try the Tether and i have discovered a small problem.
When i drive the Thrusters,light or camera tilt i get some flickering on the screen, i will take a movie of the flickering.
When i connect the control panel directly to rov,ther is no flickering on the screen.When i drive the Thrusters,light or camera tilt,sow i thing i most use a pair of Video baluns :D maybe (i will try that first)
Right now, the video wires in the tether (two 26 awg) is connected directly from camera to control panel.
Posted: Jul 21st, 2014, 5:54 pm
by TigerShark
You may also be having interference from using the same power source. I have baluns and seperate power for electronics (camera) and motors which fixed my problem.
Posted: Jul 25th, 2014, 3:15 pm
by RoarRoar
I have now add,one LC power filter on the OSD board and use video baluns,everything is working fine now,with the seabotix tether.
No more flickering on the screen :D :D
Now,i need to test the rov in seawater,and see what happens. :D
Posted: Aug 1st, 2014, 5:16 am
by RoarRoar
I have now test the rov in seawater and i discovered a major problem with the rov.
Is like a whale or seal, front of rov is diver first,sow the rov running not straight ahead,otherwise it works great.
I have try to move Thrusters more down,but its the same.
I will try to move Thrusters more forwards to front if possible,
or try to mount them on the outside and see what happen
The frame i use now,is only a test frame,sow i need to make a new one,after i have found out where i can mount horizontal Thrusters.
I have try to move Thrusters more backward,but its the same,front of rov is diver first.
I have now move horizontal Thrusters more down and more forwards to front,but front of rov is diver first. :shock:
I think those Magnetic Coupled Thrusters is to powerful ,i need to slow down speed.I have 4 gear on all Thrusters(40,60,80,100% speed), if i use gear 3 or 4,then is like a rocket.
I think, i need to use the vertical Thrusters to help to get rov running straight ahead,when i drive rov forwards.
I will use the MPU-9150 to run the vertical Thrusters.
I will try that,and see what happen.
Re: Rov from Norway
Posted: Aug 29th, 2014, 5:52 pm
by RoarRoar
I have now slow down the speed on these two horizontal Thrusters to 1000 rpm and the rov go straight ahead,but only on 1 gear.
I will take a movie soon of my rov in seawater, but i need to improve the rov to go straight ahead on 2,3 and 4 gear.
I have also try MPU-9150 to run the vertical Thrusters,but i have not find out how to do it yet. :(
The MPU9150Lib.cpp file need to be modify again :o :o
Control Systems is working good and is stable with these parts:
DFRobot 50A Current Sensor
MS5803-14BA Pressure sensor with Temperature Sensor
MPU-9150 9-axis IMU
Phidgets Precision Temperature Sensor
All information displayed on the screen with MAX7456 On Screen Display.
right now I missing auto depth and auto heading :D
Re: Rov from Norway
Posted: Sep 28th, 2014, 2:47 pm
by RoarRoar
hm
Re: Rov from Norway
Posted: Sep 28th, 2014, 2:56 pm
by RoarRoar
Hello again
I have now modified the rov some,(much better in water)i have add a weight pipe,i can add or remove weight from rov,have fix some bug,in the code.
I have not had time,to test the rov in seawater but,i shall do it soon. :D
I have upload my final code and all libraries her:
http://www.mediafire.com/download/e9qkd ... _Final.rar
Some new photos of my rov:
Re: Rov from Norway
Posted: Mar 21st, 2015, 5:40 pm
by RoarRoar
I have now made a Camcorder housing with light,and i have also add a keypad to my Control Systems.
Some new photos:
Camcorder i use is a Panasonic Lumix HC-V160 is working awesome.
I have access to all button (Photo,Rec,Zoom,on/off,Meny) on the Camcorder,I use the keypad and PS2 Controller to control it.
I can switch video,between Main camera,Hero 3 and Panasonic Camcorder.
Now I completely done with my ROV,i will now test it in seawater and have some fun with it. :D :D
Everything is pressure tested to 10 Bar,sow ROV shall not leak.
I will upload a movie,when i have test it.
I have upload my Last code,with Keypad and all libraries her:
http://www.mediafire.com/download/8g9rj ... -+2015.rar
