Hi,
not sure that i am in the right section, but i am looking for a clear dome, with a diameter of about 90mm, and deliverable in Belgium.
what i found so far was only 2mm thick, not enough for my intentions
so all ideas are welcome.
regards
Frank
Dome needed in europe
Re: Dome needed in europe
I know several people use these guys from the UK: http://www.talbotdesigns.co.uk/acrylic-domes/ – I suppose they will ship to Belgium.
Personally, I'll probably go with a flat acrylic disc instead of a dome. Because they are so much easier to get hold of. And with calculations like these http://jenswilly.dk/2013/02/calculating ... -at-depth/ you can calculate what thickness is required for your target depth.
/Jens W.
/Jens W.
Hi Frank we can make dome for you we have several in out rov shop
www.interspec.org
www.interspec.org
fpricken wrote:Hi,
regards
Frank
