ROV Camera
Our Eye's under the water.
tanner331
ROV Camera
Post by tanner331 »
Hi
I am planing on building a ROV and I was wondering if this will be a good camera for it?
Here is a link http://www.bonanza.com/booths/az_seller ... Camera_New
If not what would be?
soulreaper
Re: ROV Camera
Post by soulreaper »
It seems like it will be fine. According to the description of the camera, the worse that could happen is it could give you false colors of vegetation in low light conditions because of the infrared. At least it has infrared.
Re: ROV Camera
You'd have to build a housing for it. Other than that, the only problem I can see is that the infrared lights on the camera body might glare off of the clear part of your waterproof housing that the camera looks through.
tanner331
Re: ROV Camera
Post by tanner331 »
I was already planing on building a housing out of PVC.I am planing on one like the light housing on the seafox retrofit but with 1/4 inch plexiglass for the window.
Re: ROV Camera
Yes, they work well and are fairly easy. I've built two of those so far.
tanner331
Re: ROV Camera
Post by tanner331 »
I am building one for the lights now. I am planning on testing it in a week.
