Hi tcholas,
Cat6e would work, but I know it will not be as flexible as Cat5e, and unless you need a cable rated for a 10 gig connection, then I think it will be way overkill. Any reason for cat6e?
The DC to DC converters convert 48v to 12v @ 10A. This allows the use of thinner wire in the tether, and can supply more power to the ROV. That motor driver serves a different funtion, and would run from the 12v supply from the DC to DC converter.
For the relay, I was operating around 21v at about .5A. That relay you provided a link to is not exactly meant for this purpose as that is more to control AC power, like turing on/off lights in a house, but it just might still work - I dont know. I used dual SSR relays specifically because they are high current, and are smaller in physical size than other relays. http://www.phidgets.com/products.php?product_id=3053
Thanks,
Nick
PS2 Controller + Arduino Control System
Re: PS2 Controller + Arduino Control System
njs552 wrote:Hi tcholas,
Yes, cat5e it is really the best option!
Then you need a converter at the output of the battery to raise the voltage to 48V and another drive at the entrance of Arduino Pro Mini to lower it again to 12V?
I think a problem I would have would be with the ESC I'm using (that of the previous link), the maximum voltage that it supports the input is 43V. What would you recommend?
I will search about the relay later!
Thanks again, Vinicius
Thanks,
Nick
Hi,
If you put four 12v batteries in series the voltage adds to 48v, then 48v goes down the tether to the ROV, and inside the ROV you use a 48v to 12v converter so the motor controllers can operate at 12v, which is also about where most work best.
Here are the 48v to 12v converters I am using:
http://www.ebay.com/itm/UN3F-120W-Golf- ... 4179d913aa
You could also use a converter to bring the voltage to 48v if you don't want to use 4 batteries, or another option is a AC to 48vDC converter that would be plugged into a typical wall outlet. http://www.ebay.com/itm/48V-DC-7-3A-350 ... 25885e5560
Thanks,
Nick
Thanks,
Nick
Appreciate your help,
sincerely
Vinícius
sincerely
Vinícius
Sorry for the post, later I will post my progress on what I'm doing.
Update 1 : Bilge Pump Control
Here is the bilge pump control system using the ESC BTS7960B and Arduino Uno.
Feel free to ask anything, I'm glad if I can help, as much as I need help in a lot of things.
https://www.youtube.com/watch?v=wd_jjNh75_4
