Two brushless outrunners parallell on one ESC
Kale
Post by Kale »
I want to use two up/down thrusters. Can I connect them together assuming the ESC can deliver the current needed.
/Kale
olegodo
Re: Two brushless outrunners parallell on one ESC
Post by olegodo »
I have investigated this myself, but found out that it was a bad idea and would most probably not work or ruin your ESC.
Running two ESC's of the same signal should work though.
Please someone correct med if i'm wrong.
Kale
Post by Kale »
Ok, better safe than sorry. I will use two ESC.
Thanks!
/Kale
TigerShark
Post by TigerShark »
If you angle the two thrusters a bit you can run them opposite directions of each other to get lateral movement (crabbing) of the ROV which will make the use of another ESC more appealing.
