Where can I find the relays for a seafox build? I can not find them. Links?
Thank you!
Which Relays?
- Contact:
- thegadgetguy
Re: Which Relays?
These ones work great:
http://media.digikey.com/pdf/Data%20She ... Relays.pdf
They're sealed, so it makes potting easy, if you plan to go that route with a seafox build.
- Contact:
Re: Which Relays?
Great thanks! Any particular place you buy them from? I want to build a control interface like the one here: http://www.homebuiltrovs.com/howtojoystickhbridge.html
- thegadgetguy
Re: Which Relays?
Whoops, just realized they don't make those anymore! Well, here's a pretty similar alternative:
http://pewa.panasonic.com/assets/pcsd/c ... atalog.pdf
You're going to want the 8 pin version, the ACT212, if I'm not mistaken. Here's a link to it on Digi-Key:
http://www.digikey.com/product-detail/e ... -ND/644613
Re: Which Relays?
Are these relays single or twin??. has anyone got a wireing diagram for them, the ones steve used were double contacts and needed less wires fron control unit. contact me direct jeffbakewell@btinternet.com with info on these relays..
