dump you ballest
jeff
dump you ballest
Post by jeff »
Any ideas on useing a low volage soliniod as a ballest saftey trick, i.e. If the soliniod is possative when you power up, it can be used as a trigger, therefor if you have a total power loss the soli returns to rest thus dumping ballest and a rapid rise to the suface, just a thought for anyone..
willofgod
Re: dump you ballest
Post by willofgod »
I am thinking of doing something very much like that. I haven't completed my thought process on it though and will probably include a 'broken tether' signal as well.
bikerbones1968
Post by bikerbones1968 »
I had an idea once to use a RC failsafe or auto pilot type system. A lost signal results in relay tripping, activating a solenoid on a small compressed air cylinder inflating a "return to surface balloon." Then I decided to use a tether with a kevlar braided web inside. Just drag it up. Much easier... :lol:
