Powering my IR Camera?
Our Eye's under the water.
bigdavevw
Post by bigdavevw »
Hi guys, i,m just wondering how i should power my camera. It is an IR one, with 36 LEDS or something like that. I,m just wondering if i should run it from the truck battery i,m going to use to power the ROV, or if i should buy a seperate one?
Do they use a lot of power with all those LEDS?
Would a 12v motor bike battery be ok?
How many Ah would be ok for it?
Dave
Rover
Re: Powering my IR Camera?
Post by Rover »
Hi Dave, most of the smaller consumer surveillance type cameras do not use a lot of power. I would connect up a VOM (volt/amp Meter) in the amp setting and measure how much power the camera draws with the IR LEDS on and off.
The biggest hurdle you will have, is the voltage drop at the end of the ROV end of the tether (caused by the power draw for the thruster motors).... If it gets to low, the camera will get grainy. I would bench test everything, then water test the ROV to see if you have any voltage issues.
bigdavevw
Post by bigdavevw »
Hello! thanks for the reply. I,m using a 100 meter tether, i take it speaker wire would be enough?
Cheers
Dave
