perspex domes
Any miscellaneous pieces and parts that don't fit in the above forums.
mikec
perspex domes
Post by mikec »
I'm having trouble sourcing perspex domes. The security camera ones can be ok, but I want something with a much shallower curvature to prevent optical distortion.
For shallower dives I can make do with a flat perspex disc, but for deeper work a slightly curved portal would be better. I'm wanting to mount it on 125mm pvc pipe. Does anyone know of a reliable source, or is it better to have one custom made?
bikerbones1968
Re: perspex domes
Post by bikerbones1968 »
Hi Mike, the link below is where I purchased my dome and you can pretty much configure what you need from diameter, dome depth, material thickness and flange width.
http://www.cleardome.com/smalldomes.htm
Very good prices in my opinion and far stronger than the standard CCTV dome.
Anthony
