Homebuilt Rov Forum
It is currently May 20th, 2013, 8:32 am
Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2, 3  Next
Author Message
 Post subject: Re: Measuring tool
PostPosted: Feb 7th, 2012, 10:05 pm
Offline
I know light can travel in a vacuum, but I don't think the tool is normally used in a vacuum. lol. We would have a computer do these calculations. We will have a color camera on board so I think we will be able to see the laser and aim it at the PVC.
Top
 Profile
PostPosted: Feb 7th, 2012, 10:16 pm
Offline
Cool. How do you plan to interface the computer with the laser? As for the tool being used in a vacuum, couldn't the same be said for it being used underwater? :lol:
Top
 Profile
PostPosted: Feb 7th, 2012, 10:31 pm
Offline
Touché. We will probably either look at the reading with a camera, unless we can hack it and send it over an Arduino as an input.
Top
 Profile
PostPosted: Feb 8th, 2012, 5:35 am
Offline
standard speed of light = c ( in a vacuum )
in air the speed of light is almost the same as in a vacuum ( = c / 1.0003 )
in water the speed of light is c / 1.333
most measuring tools are designed for working in air, so when use in water you have to recalculate the distance
cool diy projects on a laser rangefinder:
http://hackedgadgets.com/2010/11/24/laser-range-finder-build/
http://diydrones.com/profiles/blogs/30-laser-rangefinder
Top
 Profile
PostPosted: Feb 8th, 2012, 10:12 am
Offline
will a kinect work underwater?
Top
 Profile
PostPosted: Feb 9th, 2012, 9:50 pm
Offline
I'm sure it does, but to get correct dimensions/measurements for underwater use I'm sure tons of work would have to be done on the software side. I also think it might be a bit much overkill, unless maybe you go fishing with your ROV or something. :P
Top
 Profile
PostPosted: Feb 16th, 2012, 10:48 pm
Offline
I guess it really depends what your measuring, what if you just carried a pair of 1"x1" maker cubes, laid them next to what your trying to measure and then calculated whatever distance you needed from a still shot? Or like someone said, a ruler, you lay the ruler in parallel to the pipe or whatever your measuring, then stand back and take a picture? Thats some basic math right there, you could probably have a kid crunching those numbers on a pad and paper once you took a picture for him.
You just need a fixed reference to measure from. It would be cheap at least.
Top
 Profile
PostPosted: Feb 17th, 2012, 12:45 pm
Offline
Hi ltdcruze,
You might like to look at the 'Parallax' Laser Range Finder.
http://www.parallax.com/
or
youtube video "very cheap homemade cam range finder (LIDAR) programed in visual c++ 2008 express"
Max
Top
 Profile
PostPosted: Feb 23rd, 2012, 3:22 pm
Offline
If you're just trying to measure the size of an object under water you can try using two simple laser pointers.
The pointers would be attached to your frame so that they are exactly parallel to each other and say a foot apart. You then can shine the lasers on the object and the then estimate the over all size of the object by looking at the distance of the two laser dots compared to the whole object.
-Steve 8-)
Top
 Profile
PostPosted: Apr 18th, 2013, 1:02 pm
Offline
Two Lazers mounted in perfect distance apart would be an idea. I saw an ROV that look like a cube with a setup like that. AC-ROV
Top
 Profile
Who is online
Users browsing this forum: No registered users and 0 guests
Search for:
Jump to:
