Hydrophone
PaulC
Hydrophone
Post by PaulC »
Need help with hydrophone... Can anyone answer me as to how to solder to the ceramic disk on a piezo disk? My solder job keeps coming loose.
lostcaggy
Re: Hydrophone
Post by lostcaggy »
If I remember correctly you scrape away some of the white coating and you also need a special lo temp solder
SoakedinVancouver
Re: Hydrophone
Post by SoakedinVancouver »
Check around for solar cell soldering flux, it might help.
I remember reading in a very old Popular Mechanic (not that I am very old, I just like reading the old stuff) the following trick: On a wheel (like, a sharpening stone wheel), you grind some solder. Then from the same wheel, you barely touch the material you want to solder to, transferring, via friction, the solder from the wheel to the , in your case, ceramic. They stated it worked for glass as well. I presume a low temperature solder would be great for that trick. And use flux as well. I REALLY love that solar cell flux, 'comes in a pen. Read the instructions, it's drippy.
PaulC
Re: Hydrophone
Post by PaulC »
Will do thanks for the info.
