To post a picture from a third party image in your post you just need to know the image location such as ...
http://i28.photobucket.com/albums/c208/SubInc/mayfair4.jpg
... you can the just hit the Img button above and paste the image location in between the [img][/img] that it adds.
Your post would look like this...
____________________________________________________________________________
You type would start here and continue until you wanted to show a picture.
[img]http://i28.photobucket.com/albums/c208/SubInc/mayfair4.jpg[/img]
You can then type more and add more pictures as you see fit.
....continued in relay (next post)
How to post pics from a 3rd party server (i.e Photobucket)
Re: How to post pics from a 3rd party server (i.e Photobucke
________________________________________________________________________________________________________
The only down side to this method is if the image location changes on the third party server, is moved, or deleted your post will show a bunch of these (see below) and your entire post may then be deleted by the admin. I'd pefer you just uploaded your images to the forum server.
(these are bad )
(these are bad )
this is a step by step photobucket tut i did for a different fourm that includes signup and resize (just cause not everyone is born a computer wiz ). just remember if you delete your pics from photobucket they are no longer posted anywhere, ie here. then admin will find you , tie you to their rov and submerge .
http://forums.dfoggknives.com/index.php?showtopic=17266
hope this helps
(admin if you dont want this up or want it customized for this site just remove it and pm me.)
hope this helps
