Hey Everyone!
Just curious if anyone has ever worked with Versimold?
I stumbled across it today in while doing some research, and immediately thought of a few places in my ROV that i could use this stuff...
http://versimold.com/
Thoughts?
Versimold - Make your own rubber parts
- KR2_Diving
Re: Versimold - Make your own rubber parts
I actually love it. It makes sugru look like play doh!
Any idea of the shore hardness? We'd be looking at 70 ish for gaskets. Though for claw grippers, bump strips etc it looks the dogs danglies
- KR2_Diving
Im looking for more technical info on the Versimold... (Sent email to Mfg... will post reply here.)
Had not heard of SUGRU before... but now... first order placed!
Thanks for the tip!
Thanks for the tip!
- KR2_Diving
Got some details from the guys over at Versimold.
So there you have it!
Are there any other products out there similar to this?
Just for comparison sake, I have compared Versimold to Sugru to PVC (wire insulation).Our Versimold product (once cured) has a dielectric strength of 400v/mil, shore A hardness is 55-60, density is approximately 1.15 (depending on color), and tensile strength of 9 MPa.
Code: Select all
Products at a Glance
Versimold Sugru PVC (wire insulation)
Dielectric Strength - 15.7kv/mm 15.6 25kV/mm
Volume Resistivity (Ohm)- n/a 10^14 10^14
Shore A Hardness - 55-60 70 70-95
Density (g/cm^3) - 1.15 1.3 ~1.4
Tensile Strength (MPa) - 9 1.89 ~20
