Sharing some basic Solidworks files.
These are just some Solidworks files of standard Bilge Pump Thrusters Parts, PVC pipe, and some Fittings that I am sharing. Pretty basic stuff if you know CAD but these might help someone save some time in designing their Rov in the future so I figured what the hell. Files are zipped but are all in .SLDPRT format. There are a lot of PVC manufactures out there but these are about 99% correct as far as most of the outside dimensions go for the parts I had on hand.
Re: Sharing some basic Solidworks files.
Thruster Parts
(Pump Tabs have been trimmed)
(Prop is just for looks. 50mm Dimension is correct but blade shape is not correct) Assembled Parts
- Mayfair 750 GPH Pump.jpg (57.15 KiB) Viewed 15896 times
- Mayfair Pump 750.zip
- (317.79 KiB) Downloaded 990 times
- Pipe Clamp One and Half Inch.jpg (52.93 KiB) Viewed 15896 times
- Pipe Clamp One and Half Inch.zip
- (460.11 KiB) Downloaded 953 times
- PVC One and Half Inch Pipe Motor Mount.jpg (38.65 KiB) Viewed 15896 times
- PVC One and Half Inch Pipe Motor Mount.zip
- (55.72 KiB) Downloaded 962 times
- Prop Adapter.jpg (49.74 KiB) Viewed 15896 times
- Prop Adaptor.zip
- (529.72 KiB) Downloaded 990 times
- Nut 4mm.jpg (41.48 KiB) Viewed 15896 times
- Nut 4mm.zip
- (192.33 KiB) Downloaded 947 times
- Prop 50mm.jpg (41.77 KiB) Viewed 15896 times
- Prop 50mm.zip
- (282.85 KiB) Downloaded 1051 times
1/2" PVC Pipe & Fittings
(The look of the 1/2" 90 degree fitting is off a little but still useable.)
- PVC Half Inch Pipe.jpg (36.99 KiB) Viewed 15896 times
- PVC Half Inch Pipe.zip
- (50.65 KiB) Downloaded 929 times
- PVC Half Inch T.jpg (39.67 KiB) Viewed 15896 times
- PVC Half Inch T.zip
- (164.17 KiB) Downloaded 963 times
- PVC One and Half Inch End Cap Round.jpg (35.12 KiB) Viewed 15896 times
- PVC Half Inch End Cap Round.zip
- (116.2 KiB) Downloaded 958 times
- PVC One and Half Inch End Cap Flat.jpg (34.12 KiB) Viewed 15896 times
- PVC Half Inch End Cap Flat.zip
- (84.28 KiB) Downloaded 896 times
- PVC Half Inch Coupler.jpg (42.08 KiB) Viewed 15896 times
- PVC Half Inch Coupler.zip
- (100.46 KiB) Downloaded 926 times
- PVC Half Inch 90.jpg (39.99 KiB) Viewed 15896 times
- PVC Half Inch 90.zip
- (159.76 KiB) Downloaded 946 times
More various Pipe and Fittings
- PVC Two Inch End Cap Round.jpg (38.97 KiB) Viewed 15896 times
- PVC Two Inch End Cap Round.zip
- (141.07 KiB) Downloaded 975 times
- PVC Two Inch Pipe.jpg (38.99 KiB) Viewed 15896 times
- PVC Two Inch Pipe.zip
- (61.25 KiB) Downloaded 947 times
- PVC Three Quarter Inch Pipe.jpg (37.76 KiB) Viewed 15896 times
- PVC Three Quarter Inch Pipe.zip
- (50.72 KiB) Downloaded 941 times
- PVC One and Half Inch Pipe.jpg (41.22 KiB) Viewed 15896 times
- PVC One and Half Inch Pipe.zip
- (58.84 KiB) Downloaded 913 times
- PVC One Inch T.jpg (42.61 KiB) Viewed 15896 times
- PVC One Inch T.zip
- (155.19 KiB) Downloaded 939 times
- PVC One Inch Pipe.jpg (39.11 KiB) Viewed 15896 times
- PVC One Inch Pipe.zip
- (57.02 KiB) Downloaded 981 times
Got your basic Solidworks files . It was much needed.
- Contact:
Thanks for this great post well done
I've added some DXF files of the bilge pump in case that can help with your designs.
Cheers,
Ramjet.
Cheers,
Ramjet.
- Bilge Pump.zip
- (41.37 KiB) Downloaded 521 times
- Bilge Pump 2.JPG (122.39 KiB) Viewed 9723 times
