SJ4000 full control hack with uw-casemod
Our Eye's under the water.
ROVER3D
Post by ROVER3D »
Here is my way to control the sjcam sj4000 full outside the case.
  • - All connections are made (include USB)
    - you can use all buttons
    - can change sd-card and
    - test cam with battery (yes you can place it in when cable is outside)
    - easy to connect to ROV-Control cam-control
Connect USB is very fricky but its the only way to get it connected (no other place on pcb found - if you fail you can only access by change sd-card - its still possible)
All cable connections have to be fixed by glue.
Watch this video for disassembly SJ4000 first:
https://www.youtube.com/watch?v=cOCl0HkeYXM
will sell pcb and pin-holder at my shop.
Download full and best quality document -.pdf (20MB): http://www.rov-control.com/download/sj4 ... h_case.pdf
i recommend using original sjcam sj4000(!)
ROVER3D
Re: SJ4000 full control hack with uw-casemod
Post by ROVER3D »
part two
