Any EasyTransfer.h experts out there? Im looking for help
Anything to do with programing the Arduino Platform.
ThunderKeep
Post by ThunderKeep »
I have an issue when trying to add sensor data to my setup,
Heres the layout,
- UNO in the ROV
connected to sensors(temp, voltage)
IC2 to PCA9685 for servos and ESC
0RX and 1TX go to a Fathom S Tether Interface board for RS422 comms -to the other Fathom S board connected to RX00 and TX01 on a Mega2560 - This is my topside control board.
IC2 to 20x4 LCD for sensor display
2 Pots on analog for some servo control(for now, just working with 2 pot and 2 servos right now, starting slow)
Since Im a beginner I have been coding everything on 1 Mega, getting the bugs worked out and then splitting the code across my 2 boards and the EasyTransfer.h library for communications
I had my split code working perfectly with just the topside board giving pot values and the bottom board moving the servos for my camera turret. So I wanted to move onto my sensor array, and started coding it as one piece and got it working perfectly. But when I tried to split it apart things go sideways. my servos are really laggy and jumping when they were decently smooth and none of my sensor data is showing on my LCD. The LCD shows the right wording but the values are just 0. I tried deleting one of the sensor equation to see if sending less data made any difference but it did not, bottom side code is still less the one water sensor,
Here are the codes
Topside Mega
Code: Select all
#include <Servo.h>
#include <EasyTransfer.h>
#include <LiquidCrystal_I2C.h>
#include <Wire.h>
#include <OneWire.h>
#include <DallasTemperature.h>
EasyTransfer ETin, ETout;
#define SERVOMIN  160 // this is the 'minimum' pulse length count (out of 4096)
#define SERVOMAX  430 // this is the 'maximum' pulse length count (out of 4096)
LiquidCrystal_I2C lcd(0x27,20,4);  // set the LCD address to 0x27 for a 20 chars and 4 line display
struct SEND_DATA_STRUCTURE{
  int TiltPot = 8;   //Analog Pin 8 - Pot for doing tilt
  int TiltVal;       //Varable reading from analog pin of pot
  int PanPot = 9;  //A P 9 - Pot for Pan
  int PanVal;     //Varable reading from analog pin of pot
struct RECEIVE_DATA_STRUCTURE{
float Celcius=0;
float Fahrenheit=0;
int offset1 = -272;// set the correction offset value for voltage sensor 1
int offset2 = -182;// set the correction offset value for voltage sensor 2
int ROVtempPin = 5; // Temp input pin of ROV sensor
int BattV1 = 0; // Analog pin of #1 sensor
int BattV2 = 1;  // Analog pin of #2 sensor
double voltage1;
double voltage2;
float tempF1;
float tempC1;
int tempReading1;
double tempK1;
//give a name to the group of data
RECEIVE_DATA_STRUCTURE rxdata;
SEND_DATA_STRUCTURE txdata;
void setup() {
   Serial.begin(38400);
  //start the library, pass in the data details and the name of the serial port. Can be Serial, Serial1, Serial2, etc.
  ETin.begin(details(rxdata), &Serial);
  ETout.begin(details(txdata), &Serial);
  lcd.init();                      // initialize the lcd
  lcd.init();
  lcd.backlight();
void loop() {
  txdata.TiltVal= analogRead(txdata.TiltPot);
    txdata.TiltVal= map(txdata.TiltVal, 0, 1023, SERVOMIN, SERVOMAX);
  txdata.PanVal = analogRead(txdata.PanPot);
    txdata.PanVal = map(txdata.PanVal, 0, 1023, SERVOMIN, SERVOMAX);
ETout.sendData();
  for(int i=0; i<5; i++){
  ETin.receiveData();
  lcd.setCursor(0,0);
  lcd.print("BatV1 ");
  lcd.print(rxdata.voltage1);
  lcd.print("V");
    lcd.setCursor(0,1);
    lcd.print("BatV2 ");
    lcd.print(rxdata.voltage2);
    lcd.print("V");
      lcd.setCursor(0,2);
      lcd.print("Water Temp ");
      lcd.print(rxdata.Fahrenheit);
      lcd.print("F");
        lcd.setCursor(0,3);
        lcd.print("ROV Pod Temp ");
        lcd.print(rxdata.tempF1);
        lcd.print("F");
 delay(10);
ROV Bottom UNO
Code: Select all
#include <Adafruit_PWMServoDriver.h>
#include <Wire.h>
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver();
#define ONE_WIRE_BUS 5
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
// our servo # counter
uint8_t servonum = 1;   // 0 is Servo for camera tilt 1 - Servo for camera side to side
 float Celcius=0;
 float Fahrenheit=0;
int volt1;
double voltage1;
int volt2;
double voltage2;
float tempF1;
float tempC1;
int tempReading1;
double tempK1;
void setup() {
  pwm.begin();
  pwm.setPWMFreq(60);  // Analog servos run at ~60 Hz updates
  yield;
  sensors.begin();
  pinMode(ONE_WIRE_BUS,INPUT_PULLUP);
void loop() {
  for(int i=0; i<5; i++) {
     ETin.receiveData();
    pwm.setPWM(0, 0, rxdata.TiltVal);
    pwm.setPWM(1, 0, rxdata.PanVal);
  // Battery Pack 1 voltage sensor
  txdata.volt1 = analogRead(txdata.BattV1);// read the input
  txdata.voltage1 = map(txdata.volt1,0,1023, 0, 2500) + txdata.offset1;// map 0-1023 to 0-2500 and add correction offset
  txdata.voltage1 /=100;// divide by 100 to get the decimal values
 // Battery Pack 2 voltage sensor
  txdata.volt2 = analogRead(txdata.BattV2);// read the input
  txdata.voltage2 = map(txdata.volt2,0,1023, 0, 2500) + txdata.offset2;// map 0-1023 to 0-2500 and add correction offset
  txdata.voltage2 /=100;// divide by 100 to get the decimal values
/////////// ROV Pod Temp
 txdata.tempReading1 = analogRead(txdata.ROVtempPin);
  txdata.tempK1 = log(10000.0 * ((1024.0 / txdata.tempReading1 - 1)));
  txdata.tempK1 = 1 / (0.001129148 + (0.000234125 + (0.0000000876741 * txdata.tempK1 * txdata.tempK1 )) * txdata.tempK1 );       //  Temp Kelvin
  txdata.tempC1 = txdata.tempK1 - 273.15;            // Convert Kelvin to Celcius
  txdata.tempF1 = (txdata.tempC1 * 9.0)/ 5.0 + 32.0; // Convert Celcius to Fahrenheit
////////////Water Temp
 ETout.sendData();
   delay(10);
PhilA
Re: Any EasyTransfer.h experts out there? Im looking for hel
Post by PhilA »
Hi there,
Not sure if you have seen this link or if it will be of any help but it has 2 x Nano's communicating using easy transfer, http://www.techmonkeybusiness.com/rov-c ... ition.html
Oldsirhippy
Post by Oldsirhippy »
If your code works fine as a single unit and fails when you connect the cable up with RS422, I would suggest looking more closely at the cable arrangement.
RS 422 and 485 are good for 4000ft at 100Kbps - so it looks like you are within specification regarding distance and speed.
Some things to try:
- If you have an oscilloscope, look at the signal you are receiving at the ROV end and compare it to the signal you are sending at the controller.
- keep lowering the baud rate and see if you can get a stable signal.
- Are you using twisted pair wires for the RS422?
- Is the cable shielded? you may be picking up interference from strong external signals, especially if you have a big drum of wire
