Homebuilt Rov Forum
It is currently Jan 18th, 2018, 2:00 pm
Post new topic Reply to topic  [ 1 post ]
Author Message
PostPosted: Mar 3rd, 2017, 1:48 pm
Offline
I've been playing with thermistors, and after much trial and I error found that simply digital toggling a pin with the right size resistor connected to ground gives you enough noise to make oversampling work well with 3.3v promini style boards:
https://edwardmallon.wordpress.com/2017/02/27/enhancing-arduinos-adc-resolution-by-dithering-oversampling/
The overhead for adding 2-4 bits of extra ADC resolution is pretty small, but the 4n power relationship balloons up quickly after that. Personally I think the sweet spot is oversampling for 4 extra bits with 256 readings. Anyway, this should work with any resistance based sensor, provided there are no capacitors nearby to squelch out your noise signal.
Top
 Profile
Who is online
Search for:
Jump to:
