building/buying an rov
Posted: Sep 7th, 2011, 10:13 am
by rec
hello, i have just joined here to see if anyone can point me in the right direction.
i have zero experience with rov's
i need to buy/build something that can go to about 100FT, be able to withstand a slight tide/current and have a good camera and lighting to see through murky water.
i know nothing about rov's, i cannot afford a commercial one, even a small commercial one i have seen is 25k+
my budget is about $1 or 2k only, is it possible to build something decent for that? is there anyone selling any kits, plans?
thanks
rec
Re: building/buying an rov
Posted: Sep 7th, 2011, 1:00 pm
by bossfrog
Welcome, you've found the right place to find everything you need to build a ROV. I'm currently in the planning/gathering parts stage. My goals are similar to yours, want to get to 100 feet. If your water is murky, I doubt that any camera will be very effective seeing thru it.
Posted: Sep 8th, 2011, 3:52 pm
by Rover
Welcome.
The most common building material used is PVC pipe. It is available at your home improvement store and is easy to cut and glue together.
There is a ton of information on this site that will help you as you begin to design and build your ROV.
To begin you will need to identify:
Number of thrusters (left, right and vertical thrusters)
Control method (as simple as a relay, to micro processor boards)
Camera (like the smaller board type security cameras)
Camera lighting (LEDs are a great choice, as they have a lower current draw)
Tether design (houses the control, power and video wires)
Topside control (as simple as a 4 or 8 position joy stick to computer controlled software)
Hull design (the more stuff you have the bigger the hull)
Good luck, and keep us posted on how your build is going.
-Jim
