Test setup for outrunner motor
rehoward
Post by rehoward »
I just bought an outrunner motor from HobbyKing with the following specs:
Kv(rpm/v) 700
Weight (g) 78
Max Current(A) 13
Resistance(mh) 0
Max Voltage(V) 11
Power(W) 0
Shaft A (mm) 4
Length B (mm) 38
Diameter C (mm) 40
Can Length (mm) 10
Total Length E (mm) 78
I also bought an ESC from HK claiming input of 5-13 volts like this:
Features:
Full protection feature including low voltage, over-heat, throttle signal lost, startup
protection and self-check.
Compatible with sensorless brushless motor.
Excellent startup performance, linear and quick throttle response.
Supports highest motor speed 240,000RPM(2 poles), 80,000RPM(6 poles) and 40,000(12 poles).
Easy to configure with program card.
System can automatically detect throttle neutral point, and neutral range is adjustable.
Three work modes for different environments.
4 step reverse force adjustment
5 step start force adjustment.
3 step brake force adjustment
5 step drag brake force adjustment,
4 step initial brake force adjustment.
Specification:
Input voltage: 2-3S Lithium batteries / 4~9 Ni-xx
Cont. Current: 30A
BEC output: 2A /5V (Linear)
Size( length X width X high): 45x32x20mm
Weight: 51g
I have a switched 12DCV power supply capable of claimed 30 amp max power.
So my question is this, can I safely test this motor with this ESC and power supply under load or must I use batteries? I could buy a second DC power supply and wire the two in parallel if more amp capacity is needed. What do you think?
Randy
puzzler300
Re: Test setup for outrunner motor
Post by puzzler300 »
In all honesty, you probably could, though I'd be wary. My motors are rated to that same 13 amps, but I've measured it up to at least 20. So my advice would be to wait until you know the max draw of your system in order to protect your power supply.
Note* I don't know a lot about power supplies, so I could be wrong.
Jaman42
Post by Jaman42 »
Use a fuse?
