stuffing box and prop size
Posted: Nov 3rd, 2013, 9:46 am
I'm looking at using 12volt, 1000rpm brushed gear motors and am wondering about the pros and cons of running the prop shaft through a stuffing box, similiar to this, http://letsmakerobots.com/node/19254
Also, since this is a low rpm motor, I should be using a bigger prop. I would like to keep the amp draw lower than 10, any ideas as to a good sized prop? I was looking at 4 or 5 blade props between 2-3 inches, but im just guessing. Thanks!
