Homebuilt Rov Forum
It is currently Feb 23rd, 2018, 10:11 pm
Post new topic Reply to topic  [ 4 posts ]
Author Message
PostPosted: Aug 26th, 2017, 6:18 pm
Offline
I am planning on building my ROV with the main control systems and power onboard. Originally, I had planned on running some form of web server on the Arduino or Raspberry Pi and accessing it from my computer. If I do that, I would have to remove a few wires to run the analog video signal to the surface.
Is there a way to run a website on a Pi and input RCA video to it, which could be seen on my laptop using a direct connection to it?
I would then receive inputs from buttons pressed on the site, which would send commands to an Arduino to run the motor controllers.
Would that be possible? Would that be almost the simplest way?
Top
 Profile
PostPosted: Aug 31st, 2017, 2:58 pm
Offline
I just started messing with Raspberry Pi's so I'm a total noob but have a look at the Bluerobotics stuff they are using Pi's in their Rov's you might be able to get some ideas from them.
Top
 Profile
PostPosted: Sep 6th, 2017, 4:39 am
Offline
Possible, sure... if you have the skills or the time to master/learn them.
Some have gone this path, Shameless plug of my software/setup https://github.com/Moki38/Moki-ROV2
The easier path is the BlueRobotics path (ardusub), just buy what you need.
Top
 Profile
PostPosted: Oct 26th, 2017, 7:54 am
Offline
Some cameras have there own webserver "inside", in that case you can plug that a frame of your PI webpage and you are up and runing. Or connect to two webpages from the top side computer so lag from feed one does not harm feed two directly.
Top
 Profile
Who is online
Users browsing this forum: No registered users and 1 guest
Search for:
Jump to:
