Brushless ESC control question
Noj504
Post by Noj504 »
So I would like to use brushless DC motors and I know I need to use a brushless ESC. What is the simplest way to control this set up? I know relays will not work and I would rather not get in to programming anything so I was considering Rheostats, anyone have any idea if this will work?
Re: Brushless ESC control question
No, rheostats will not work.
An ESC requires a pwm (pulse width modulated) signal as an input.
If you want to stay away from having to program things probably the simplest option is to use an rc transmitter with a trainer port, a ppm to pwm converter or a dsc equipped rc receiver, and a two wire tether to connect the two.
Noj504
Post by Noj504 »
Thanks, I'll look in to that. This is the weak part of my rov game...actually this is my first rov so its all pretty weak. Ha Ha
Agree with Steve's suggestion as a simple full control system, but you can connect a servo tester to your ESC (simulates the signals coming out of an RC receiver)
https://www.hobbyking.com/hobbyking/sto ... ester.html
