needing a bit of advice regarding LED and controllers
Illuminating the Abyss.
jonnyhas
Post by jonnyhas »
Hi guys, am trying to figure out the best way to setup lighting on my rov, i will be running on board power 3s batteries 10-12 volts, i have read all the precceding post and am trying to get my head round using a meanwell LDD and what current rating to use, for instance if i run to 10 watt leds @ nominal 11v = 0.9A do i have to have a controller rated @ 1A ie meanwell LDD 1000 to run this or will a meanwell LDD - 500 do it but it just wont be as bright?
cheers John
